LIFTING 2005 VIBE!!! NOT BIGGER TIRES...
mango02
Post by mango02 »
Could not find anything on lifting VIBE. Just want to raise it 1" or 2" DO NOT want BIGGER TIRES. Would like to raise suspension. Springs? Bushings? Blocks? All I see is LOWERING need to go up because of rough roads.
gtv237
Re: LIFTING 2005 VIBE!!! NOT BIGGER TIRES...
Post by gtv237 »
There's not really a simple way to increase height or travel without ruining the suspension geometry.
mango02
Post by mango02 »
When you lower a VIBE you screw up the GEOMETRY. When you install different aspect ratio tires or size you screw up the GEOMETRY. Has anyone experimented and raised a VIBE? There is one RALLY VIBE did he use stock springs? does anyone make anything for a VIBE to make it TOUGHER, STRONGER? Does Toyota TRD make anything for a MATRIX Corolla? Skid Pan like VW makes for the JETTA?
Derf
Post by Derf »
Link to a thread on the Vibe:
viewtopic.php?f=30&t=40933&p=482114&hil ... ft#p482114" onclick="window.open(this.href);return false;
Which ultimately leads to a link on a Matrix with the same suspension.
http://matrixowners.com/index.php?/topi ... trix-lift/" onclick="window.open(this.href);return false;
I have not seen an actual skid plate, but this is at least metal.
http://www.kamispeed.com/BEATRUSH-Alumi ... 516010.htm" onclick="window.open(this.href);return false;
mango02
Post by mango02 »
DERF thanks! skid pan looks good for me. The lift looks good but unable to go that route. No PLASMA cutter and no TIG welder. Thanks for the THREAD!!! DERF.....
mango02 wrote:When you lower a VIBE you screw up the GEOMETRY. When you install different aspect ratio tires or size you screw up the GEOMETRY. Has anyone experimented and raised a VIBE? There is one RALLY VIBE did he use stock springs? does anyone make anything for a VIBE to make it TOUGHER, STRONGER? Does Toyota TRD make anything for a MATRIX Corolla? Skid Pan like VW makes for the JETTA?
He is on stock suspension with a skidplate in front.
Doug14
Post by Doug14 »
Almost $300 for that skidplate!? holy cow!
The rally Vibe has AWD front springs (AWDs are slightly raised) and 09 rears, though the spring rate in the rear may be a bit much for the lighter car. The skidplate is a custom plate of really thick metal. Next time I'm there I can inquire.
