Hi,
I have a 04 GT with 107 K. I have to replace the rear "Y" portion of the e brake ables that lead to each rear brake, as one is locked up. By locked up, I mean the e brake lever, when applied, does almost nothing and the car can move easily on a hill. I tried adjusting the lever, but to no avail. The rear brakes were just completely redone last fall, so I am assuming that is not the issue.
I tried to locate some threads on this and found one that references the replacement part is not available thru GM anymore, which is fine as I have a Toyota dealer here in town. I plan on taking the original off when I get the new one to make sure the Toyota replacement is the same.
Question really is there a thread that references the procedure for replacing the cable assembly? Do I have to take the rotor and inner e brake shoe assembly completely apart in order to replace the cable sections, or maybe not? My Haynes manual does not reference this at all. Any advice would be appreciated if for no other reason, maybe i can estimate how much time I should set aside for the repair.
I will be able to completely take my time as it is parked for the winter, so I can just do a little here and there if that is what it takes?
Thanks
Todd
