Hi all,
I have an 03 base 200k, the other night had some starting issues... came on quick and was intermittent no-crank. Of course it was the zero degree day so I replaced the 4 year old battery, still no love. Intermittent cranking.
Replaced the starter with a reman... It's only been a day, so I'm not sure if its intermittent or non-existant, but I haven't gotten a crank yet with the key. What I've found is this:
I get 12v to the s terminal and it sounds like it pops the gear out. However, it doesn't spin the motor. If I jumper the 2 posts (12v battery to motor side) with a screwdriver while someone has the key turned, then it cranks and starts. Am I really unlucky enough to have gotten a bum reman? Or could something else be causing this?
Thanks!
