tire light
nightmistwalker
tire light
Post by nightmistwalker »
is there a way to shut off the stupid low tire warning system ?,,i keep checking the tires and they all have the same pressure and every time i hit a decent pot hole or crack in the road it turns the dam light back on again,,tired of looking at the dumb thing and resetting it at every other red light,,wondering if there is a way to permanetly shut the light off?
kumquat
Re: tire light
Post by kumquat »
First you should probably do the reset procedure. It's probably just that one or more of the sensors isn't calibrated right. Turn the car to ON with the engine off then press and hold the TPMS button until the light flashes 3 times.
Re: tire light
What year is your Vibe?
nightmistwalker
Re: tire light
i reset it and it has been good since,,thanks
