2005 base vibe. 159,000 easy/highway miles.
Just the other day the temps dropped into the 20's and I'm noticing that when in 3,4,5th gear at about 2,000rpms and I floor it the motor revs up about 500-1,000rpm then drops back down and it seems as if the clutch is catching up with the motor's speed. Normal acceleration in 1st and 2nd gear. I don't flog on the car much at all, maybe every few hundred miles to get the rpm's up past 4,500 or so. Typically change gears around 3k rpm.
Is the clutch dying on me? Pedal travel is only a few inches before it engages/disengages.
...And if it is my clutch, I would like to replace it with an OEM one like the car came with. Does anyone have the part number? Also is it better to have pontiac/toyota change the clutch out? I'm assuming I'll need an alignment afterwords as well?
Thanks.
