Wanted - 5 speed transmission shift cable retaining clip
455SD
Post by 455SD »
Hi GenVibe
2003 Base Vibe (most likely 03 - 08 will be same).
I am in need of a shift cable retaining clip(transmission side of the cable). This is a horseshoe shaped spring steel retaining clip that just slides down into the groove of the OD portion of the cable and affixes it to the bracket at transmission.
Anybody have one they'd be willing to part with?
25271 is my address.
Thanks,
EnvyGreen03
gtv237
Re: Wanted - 5 speed transmission shift cable retaining clip
Post by gtv237 »
I don't have one but if you end up having to get it from the dealer, the part number is 90468-14016.
455SD
Post by 455SD »
Thanks! Currently have a piece of spring steel shaped to hold it into place and a safety retaining wire to keep it in place.
I do appreciate the part #. Still hoping someone has a spare - rather give a GV member the money, than GM.
Cheers!
EnvyGreen03
