First post so I'll give a quick background on the car. I've got a 2005 Vibe base model that I purchased used in 2010. At the time it had ~170k miles on it. It's been a great car with routine oil and filter changes. Now that I'm sitting on 220k miles, I've started doing some preventative work on it.
Over that past week I've changed the oil, oil filter, air filter, serpentine belt, spark plugs, and valve cover gasket and I ran a can of Sea Foam through with the last full tank of gas. The car is already running more smoothly and I expect will be even better after I replace the PCV valve, and clean the MAF sensor and throttle body today. Over my next weekend (I work Th-Sun), I plan to change the transmission fluid/filter, and check/clean/replace worn brake parts.
So now to my situation and question. When cleaning the surface to prepare for the new valve cover gasket, a piece of the old, dry sealant flicked off the razor blade and went down beside the timing chain. I used a dental tool to remove it and just as it was coming within reach, it dropped again and this time went all the way down below the timing chain to an inaccessible area (without major teardown). I did searches on Google and came up with basically 2 camps on this from the many similar questions asked in the past. The one says that it must be removed or will cause all kinds of problems, the other saying it's no big deal and it's just going to end up in the oil pan and will wash out with the next oil change. After replacing the gasket I started the car and drove it around a bit and noticed no ill effects. At this point, since I've run the motor and the piece of dry sealant could be anywhere, I have no choice but to wait and see if anything bad happens.
My question is, do you guys think this will just find its way to the oil pan or get broken up and cause no issues, or do you think I'm doomed to engine failure in the future because of it?
