Has anyone used Peak synthetic ATF?
jolt
Post by jolt »
I was looking for ATF replacement fluid that would meet Toyota WS standards. I found that Peak makes a full synthetic ATF that they "Also recommended for use in the following applications: Toyota Type T
Toyota Type T-II
Toyota Type T-III
Toyota Type T-IV (JWS 3309)
Toyota Type WS (Hybrid)
Toyota Type WS (JWS 3324)"
Here is a link to a PDF doc for the product: http://images.peakauto.com/PEAK%20FS%20 ... n%20LV.pdf
This fluid is available at Advanced Auto Parts for $5.99/qt. Has anyone here used this? The MSD sheets on it look to have comparable specs to Amzoil Synthetic and Toyota WS fluid but not the exact same.
Chiadog
Re: Has anyone used Peak synthetic ATF?
Post by Chiadog »
I don't think I've heard of anyone using Peak ATF, but I believe several here are using Castrol Multi-import ATF which meets T-4 and many more specs. I've seen the Castrol at Walmart and I expect to use it on my gen1 at my next ATF exchange.
triz
Post by triz »
Cant say I know anyone who has. Amsoil makes a great transmission fluid though. I am biased :mrgreen:
jolt
Post by jolt »
Thanks for the replies.
The Castrol Multi-import ATF does meet the T-IV spec for the gen1 Vibes but does not list the WS spec for the gen2 Vibes.
Amzoil has great products that I have used in the past but at ~$13/qt is up there with the Toyota ATF.
BMW ATF is only $34 a quart ;)
triz
Post by triz »
jolt wrote:Thanks for the replies.
I PM'ed you. You do get a discount for being on Genvibe. You just have to use my referral code, not be assigned to another Amsoil dealer and PM me when its complete.
