Rear View Mirror
yank dini
Rear View Mirror
Post by yank dini »
Just had to ask this dumb question. What is that wire connected to the rear view mirror??And what are those black strips along the top and sides of the windshield????
NovaResource
Re: Rear View Mirror (yank dini)
Post by NovaResource »
The wire is to power the map lights in the back of the mirror. See those 2 buttons under the mirror? Press them and the map lights go on.The dots on the windshield are there to help block the sunlight. They take up the space inbetween the sun visors when they are down.Basically the same thing on the passenger side of the windshield. There are no dots on the driver side because of the headlight sensor.
yank dini
Re: Rear View Mirror (NovaResource)
Post by yank dini »
Thanks NickNow I know and knowing is half the battleGI JOE!!!!!!!!!!!!!!!!!!!!!!(only gen x-ers knows that line)
NSimkins
Global Moderator
Post by NSimkins »
quote:Thanks NickI'm Nick.. that was Scott that posted. quote:Now I know and knowing is half the battleGI JOE!!!!!!!!!!!!!!!!!!!!!!(only gen x-ers knows that line)I know the line...
tribalman
Re: Rear View Mirror (NSimkins)
Post by tribalman »
old thread yes i know, but i think it's still relevent, how much voltage is going through those lines? i recently purchased a GPS unit and i don't like the dangling cord to the outlet. i wanna either re-route/make a 2nd plug up top, or take the line from the mirror lamps and use that. i have a 04base without moonroof.
None. Vibe is gone.
Whelan
Re: Rear View Mirror (tribalman)
Post by Whelan »
You want to hard wire your GPS to your car?I would think you would need your own switch, relay and fuse for that.
2012 GLI Autobahn 6MT
Quote, originally posted by tribalman »old thread yes i know, but i think it's still relevent, how much voltage is going through those lines? i recently purchased a GPS unit and i don't like the dangling cord to the outlet. i wanna either re-route/make a 2nd plug up top, or take the line from the mirror lamps and use that. i have a 04base without moonroof.You could use the mirror lights, but they get power from the 15 amp dome fuse in the underhood fuse block. The dome fuse is always hot. If I plug mine into a switched power source, it will auto turn off when I turn off the car, and that could come in handy. If you want to run a wire from a different source, it would fairly easy to run it up the A-pillar (between the door and windshield)
Might want to be careful if you're thinking about connecting the GPS directly to the wiring in the event yours doesn't actually run off of 12V. Sometimes they put a small power supply in the cigarette lighter plug to drop the voltage down. My handheld's power cable is that way.
tribalman
Re: Rear View Mirror (ColonelPanic)
Post by tribalman »
Quote, originally posted by ColonelPanic »Might want to be careful if you're thinking about connecting the GPS directly to the wiring in the event yours doesn't actually run off of 12V. Sometimes they put a small power supply in the cigarette lighter plug to drop the voltage down. My handheld's power cable is that way.i'm figuring that mine runs off of 5 volts because the plug in the back is a USB plug. standard USB from a computer is 5 volts. it will require a bit of work but if i find out the pin outs of the usb plug i can wire the plug into a voltage regulator then into the mirror power.joatmon, do you have a link about the switched power outlet?
None. Vibe is gone.
satur9
Post by satur9 »
heis refering to any power that turns off when you turn the car off. ie your lighter plugs and such. if you want to be able to use the gps with the car off. you could use the maplight power which is always on.you just have to remember to turn it off so you wont drain your battery.
tribalman
Re: Rear View Mirror (satur9)
Post by tribalman »
Quote, originally posted by satur9 »heis refering to any power that turns off when you turn the car off. ie your lighter plugs and such. if you want to be able to use the gps with the car off. you could use the maplight power which is always on.you just have to remember to turn it off so you wont drain your battery.i was just wondering how he had wired it, i know they turn off when the car's off
None. Vibe is gone.
