205 60 16 blizzak snow tires fit ?
markd78
Post by markd78 »
Have a 2009 2.4 with 17's, found camry 16 114.3 steelies with hubcaps, looking at almost new set of blizzaks 205 60 16, wondering about height ? I know your supposed to stay within the 3% rule on tires, any problems with the fit ??
Mark
dragon64
Re: 205 60 16 blizzak snow tires fit ?
Post by dragon64 »
There shouldn't be any problem. You will just have to remember that the speedo will be off.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
You should be just fine. If anything you'll get a tiny boost in height.
Those tires will fit on the rims, but I don't know if the rims fit on the Vibe. I thought we need 5x100,
vibrologist wrote:Those tires will fit on the rims, but I don't know if the rims fit on the Vibe. I thought we need 5x100,
The second gen 2.4s are different. They have a different bolt pattern (5x114.3). But all 1.8 Vibes have the 5x100 pattern.
Thanks for the clarification!
The stock 16" tire size for 2009-2010 Vibes is 205/55/16, so a 205/60/16 should be fine.
KITT222 wrote:The second gen 2.4s are different. They have a different bolt pattern (5x114.3). But all 1.8 Vibes have the 5x100 pattern.
Yep...
All 2003-2008 Vibes = 5x100
2009-2010 Vibe 1.8L Base = 5x100
2009-2010 Vibe 2.4L Base / AWD / GT = 5x114.3
