REmoving both side mirrors...need HELP
gpk99
Post by gpk99 »
If anyone here has the know-how on how to do this and the time to explain step-by-step instructions...any special tools needed etc...it would be muchly appreciated. It is for a 2006 Vibe
sideshowalan
Re: REmoving both side mirrors...need HELP
Post by sideshowalan »
Remove the door panel by first removing the sail panel (triangle piece in the corner). Remove 2 screws, 1 by door handle, other by the door pull. Pull panel off.
You'll then see 3 bolts holding the mirror on, undo the electrical connection to the mirror.
2008 Pontiac Vibe
2008 Toyota Sienna XLE
Derf
Post by Derf »
The following post has details on mirror removal, the video link in the first post details mirror removal starting around 1:30 Depending on why you need to remove the mirrors, the video highlights some issues you may encounter after removal.
viewtopic.php?f=18&t=42845" onclick="window.open(this.href);return false;
