The vibe has been a great car for the last 10 years or so and it's still running strong. But there were a few issues recently. When driving around 50 MPH or above, the car starts to shake, the steering wheel shakes and it seems like something is wrong. Even after driving just ~5 miles at ~50MPH or above the front driver's side rim and brake rotor were extremely hot and covered in brake dust.
So it appears there is a problem with the brakes, rotors, or wheel bearings.
I know a bit about cars but have not done a brake / rotor replacement on a vibe.
So anyway, a friend helped disassemble the vibe, the front wheels and brake calipers were removed. The brake pads and rotors appear to be OK. On the drivers side, the rotor seemed "loose" and the brake pads / caliper were stuck to the rotor... The rotor just came off the axle... (not sure if this is the correct term). The rotor on the passenger side appears to be stuck.
So anyway now the vibe is half disassembled and I'm wondering where to go from here. The rotor on the driver's side is off, the rotor on the passenger side is on. The brake pads appear OK and the rotors are smooth and seem OK.
Any input / suggestions appreciated... I just want to get the vibe working again.
So will just replacing the brakes and rotors "fix" the issue? Or maybe just replacing the driver's side wheel bearing will work? Otherwise I'll have to get things put back together and take it in to someplace.
Thanks for any suggestions / direction!
Here are some pics of the rotor and driver's side wheel well.
Or just links to the full images...:
http://i.imgur.com/De5KaWJ.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/akZiGXT.jpg" onclick="window.open(this.href);return false;
http://i.imgur.com/L75yWPv.jpg" onclick="window.open(this.href);return false;
