trb wrote:That camera looks like the one on my wife's Equinox. It is located just to the left of the hatch release button, so I bet you could install it on the plastic "Pontiac" piece that houses the hatch release and the license plate lights.
Probably. I looked at it this evening, and I thing it is very doable.
trb wrote:There looks to be enough room to drill the right size hole in the plastic next to the lights, and route the wiring through the hatch along with the rest of the lighting wires. You might have to extend the power wire to reach the back up lights, but hopefully the video cable would be long enough. You should be able to get an extension for it if necessary.
Do you think I could be able to power it from a permanent (always on) 12v in the back of the car so the camera will be available anytime even if not in reverse mode?
Also, how do I get to the rear part of the Vibe back door? There is a plastic there, but could not find how to get inside it...
trb wrote:I've been thinking about adding one to my son's radio, but just haven't really looked into it. I did look at the license plate mount ones briefly, but they just looked too cheap. The one you found looks really nice.
II had ordered one license plate camera on amazon.ca, then cancelled when I found a reference to this model on a forum. At first it looks daunting to dig hole in the car, but that must be the easy part, considering the wiring part as more difficult to accomplish. And it is certainly prettier this way. My main problem is to find it in canada at a decent price. May have to use a USA eBay vendor.
