I checked all the fuses this evening, and didn't find anything obviously blown. Under the dash and under the hood. Might have to do more searching for some wiring diagrams. The gauges, AC & fan, turn signals, power windows, automatic lights, and 115v power outlet do not work. The lights/fogs work manually, brake lights, mirrors, interior lights, power locks, wipers/washers, cruise, console, 12v plug, hatch release and radio DO all work. Several of the indicator lights work also - door open, cruise, airbag, and the AC control lights work too.
I worked on my son's radio, pulled it out and re-installed the new one several times adding the remote mic and parking brake override and never disconnected the battery. Lucky I guess!
The crank in the Mustang broke right at the front of the motor over 3 years ago. Rod through the pan and balancer wobbles about 1"out of position. I guess it lost oil pressure and popped on me while accelerating on the freeway feeder road. I have a replacement short block, newer heads, and everything needed to rebuild the new motor, just need to find the time to do it! When it is cooler!
Broke timing chain, cover and crank:
