Hello !
As of two days ago I am the happy new owner of a 2009 Vibe , base 1.8 liter engine, 5 speed manual transmission, manual windows, and manual door locks.
Any advice about maintaining the car and any insight into the car's "personality" --- quirks or unusual behavior --- which I have not noticed any at all yet would be appreciated.
Also , where to post each of these questions in the forums :
(1) RPMs
What is the proper RPM level on the tachometer for maximum life span of transmission and engine ?
Although driving in lowest RPMs possible for each gear would be optimal for fuel economy , what is the affect on transmission and engine even if able to operate seemingly smoothly at low RPMs ?
(2) Head rest
When driving the back of my my head stands a few inches in front of the head rest. What replacement head rest or head rest pillow is best for this car ? A pillow contacting higher on the back of head rather than back of neck would assumedly be more comfortable because of not radiating body heat during the warmer months.
(3) Anti-freeze
Which anti-freeze is bet to use ? I have heard Japanese manufacturers prefer red anti-freeze and American manufacturers prefer green anti-freeze , but the Vibe is branded as American Pontiac while being very Japanese Toyota.
(4) Ethanol gas
Is there any advantage to using pure gas (gas without ethanol) or adding "Lucas Ethanol Gas Treatment with Stabilizers" to normal gas in a Vibe ? Gas without ethanol is recommended for carburetor equipment --- motorcycles, classic cars, lawn equipment , etc ---- but would any parts of the Vibe benefit ?
(5) Roof rack
My Vibe does not have roof rails. If ever deciding to add a roof rack , which one is best and where to buy ?
(6) Bicycle rack
Which bicycle rack is best and where to buy ?
First thought is a rear mounted rack because of aerodynamics but what is best for Vibe ?
(7) Electrical outlet
I have not yet tried plugging any device into the electrical outlet but a forum post mentions using an electrical adapter because many plugs are not compatible with the socket. What adapter to buy ?
(8) Spare fuses
What array of fuses would be good to purchase as a set of spare fuses ?
Any advice is much appreciated.
Thanks !
Kevin
