Ground Wires
Roadpig
Ground Wires
Post by Roadpig »
I haven't found any (recent) discussions regarding grounding wires installed in the Vibe. There are some deep discussions in matrixvibe and matrixowbers forums. So I was wondering, has anyone here installed them, and of so, was it worth it/notice a difference?
2004 Vibe GT, Neptune Two ToneGraphite Interior, Moon & TunesPower Package, 17" Rims, Exhaust Tip Mods Tinted (50% front window, 35% back & rear)Cosmo Alpha Omega 3 Child Seat & Booster SeatCustom Cargo Mat, DebadgedMagnaflow Cat-back Exhaust, Injen CAI
AKLGT
Re: Ground Wires (Roadpig)
Post by AKLGT »
there are a couple of threads about the ground wires: savedbyzero: http://forums.genvibe.com/zerothread?id=5902 lancer: http://forums.genvibe.com/zerothread?id=5465
AKLGT1998 Subaru 2.5RS
disneydj
Re: Ground Wires (trdvibe)
Post by disneydj »
I did it... and to be totally honest... I can't tell the difference. But then again it only cost me about 15 dollars to do it. However insulating the A/C Line, now that was a great mod! Good luck
teammonkeys
Re: Ground Wires (disneydj)
Post by teammonkeys »
Really? What does insulanting the AC do?
2003 AWD Vibe.Satellite Silver, monotone.Fully Loaded with Machine gun mounted on top accessible via Moon Roof. Just Kidding, i have no gun but I do have a sun/moon roof.Side Airbag with shooting 6 disc changer.ilquikgtx's supercharger installed.
disneydj
Re: Ground Wires (silverawd26)
Post by disneydj »
By insulating the AC line it helps the AC cool faster. Here in Sunny Central Florida it get's hot... and when you turn on the AC you want it cool. The AC line runs right past the engine, and it heats it up, causing condensation to form on the line. The insulation keeps condenstation from happening, and insulation is real cheap... worked for me!
blk182@n7
Post by blk182@n7 »
What did you use to insulate the A/C?
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
