Th17kit wrote:I do a lot of mountain driving and I have been known to drive aggressively on those awesome mountain passes. I think it's time to invest in better performing brake pads and rotors on my 09 GT due to the progressive front steering wheel vibration ONLY when braking (started late last fall). I had the same phenomenon in my Honda Accord, and after getting new pads and resurfacing rotors the problem came back in no time. I have a few questions.
Is it necessary to replace all four sets or can I just do the front two? I imagine I must do all four.
I hear it's an easy job to DIY, but due to time constraints and the fact that I'm not naturally good at working on the car, what's a fair price for having a shop do the work if I supply the hardware?
I'd like to get some recommendations on what I should buy. I'm hoping to get good equipment that won't warp but I don't want to pay an arm and a leg if I don't need to. In searching the forum I've gathered that Stop Tech slotted rotors are good, and perhaps Hawk ceramic pads?
Hi TH:
My answer is not Vibe specific and I am not an aggressive driver (anymore). So keep that in mind. I would love to have your roads around here where it's flat.
You can do just the fronts. They do the hard work anyway. Obviously cheap rotors will do you no good. Drilled rotors would help with pad contact but they can crack starting at the holes. Dimpled rotors will enhance pad contact without the cracking issue.
Slotted rotors will increase pad wear. I would avoid them.
When you shop for rotors consider the weight. The lightest will wear out the fastest. Consider more so the overall quality. I have had good experience with Wagner products and I have had bad experience with store brand products.
I looked at Rock Auto. Unfortunately it is impossible to get consistent product information across the brands. Raybestos does a good job in providing information but that does not mean that the product is the best. But this is the kind of information I would like to get form all of the brands:
http://www.rockauto.com/catalog/moreinf ... cc=1442296" onclick="window.open(this.href);return false;
Maybe you need to go to the brand websites to find out the specifics.
I once got AC Delco rotors for a Mazda pick up. These rotors were the finest looking ones I ever unpacked. Smooth as glass and fully balanced. There was also detailed info on the web. I found no details today.
That is all I can do to add to the confusion.
