Hi, '04 GT, 104K.
I will be replacing the rear brake pads and rotors. They are disc with the emergency brake shoes inside the rotor. The caliper slides appear to be not working correctly, as the pads are not making complete contact with the rotors. I replaced the pads about 7 years ago, and I cannot recall if the slides can be cleaned up to work again, or if the calipers need to be replaced when the slides start seizing. The rotors and calipers are original, and have seen many WI salty winters. So, are the slides integrated into the calipers? I just cannot recall.
Thanks
