Is the exedy kty14 the correct clutch for the gt? There seems to be contradicting information on the interweb.
Resurface the flywheel or get a new one? Any suggestions on a new flywheel?
Thanks in advance!
I believe Exedy is the clutch Toyota uses for their cars...gtv237 wrote:I would get a Sachs brand clutch off rockauto.com. Sachs is the company GM uses for all their clutches.
That I don't know. As far as clutches go anything from an OEM will be a step up from an aftermarket replacement part.ken99287 wrote:if the KTY14 is the correct kit for the GT.
You can use flywheel shims to make up for that but you've got to think, why does a flywheel need to be resurfaced? Generally it's because it's either warped or misshapen. As you cut material off, you make it thinner. The thinner it is the quicker it heats up and the quicker it will warp or misshape. IMO it's just better to just replace it.ken99287 wrote:If that's all it costs, I'm getting a new one. They say a flywheel can only be cut twice before you start to get issues with clearances or something (too thin).
Sounds like resurfacing might be the best value to you. Just look your flywheel over good. If its visibly warped, grooved or misshapen, I would just replace it.ken99287 wrote:Rock auto has my flywheel for $58, but shipping is about $20!
Napa will cut mine for $30 and only 1 hour turnaround time.
