Phacade wrote: When I pulled the wire from the compressor and tested it for 12v it has 12v no problem.
You have 12V reaching the clutch, and the clutch in not engaging.  This could be caused by :
1.  The clutch is bad
2.  There is corrosion on the clutch electrical connector terminal, so that the 12V is getting to the end of the wire, but not making across the connector to the clutch.  You could try using a little sand paper or a piece of an emery board to try to clean the contact on the compressor, but I doubt this is the case.  Still, I'm cheap, and would try this before spending money and time on a new clutch.
2. There is no ground.  The clutch only gets one wire, which is 12V to engage, open to not engage.  This circuit requires a ground for the clutch to activate.  It gets this ground from being bolted to the engine, which is also ground.  If this were the case, either the engine is not grounded, or there is corrosion between the compressor and the engine preventing good electrical contact at the mounting surfaces.  I'd be inclined to highly doubt that either is the case.  Still, to verify, you could connect a ground directly from the battery to the compressor case to rule that out.
I think that worrying about pressure in the system is premature.  It might be low, it might be ok.  Could be high.  It Doesn't Matter Yet.  Your testing shows that the controls are trying to turn engage the clutch, and the clutch is not working.  You pretty much need to fix that issue before you need worry about any other issue that may or may not be in the system
sounds like a bad clutch to me, but that's from my perspective here across the ether, and as much as I hate to admit it, I can be wrong sometimes
