easy diy pet barrier
My first adaptation was a pet barrier. I found a panel of VersaPad at a local Theisen’s farm supply store for about $20. The overall size is 4ftx 2ft and it is large enough to make 2 pet barriers. VersaPads are made of a plastic with 1 1/8” o. c. grid. They are easy to cut with a straight blade hand saw or a table saw.
This picture shows two versions. On top is the final version which provides better rear view vision than the first version at the bottom. You may count out the squares to copy the design. The top version is 8 squares high. The top corners are cut by 4 squares in the top row and 2 squares in the second row. The rear view slots are 2 squares high and 13 squares wide, the lower slots are 7 squares wide.
Pontiac Vibe 047.JPG (110.85 KiB) Viewed 5723 times
Re: easy diy pet barrier
I attached the barrier to the head rests using 2 nylon straps (yellow, about 40”) and 2 lengths of strap (white, about 36”) to keep it from migrating down. The white strap is tied to the grid just behind the headrest. The loose end of the strap runs over the headrest and is tied to the head rest post. This fixes the height of the barrier. Of course I have cut the excess off in order to make it look neater. I intend to switch to all black straps to match colors.
Pontiac Vibe 048.JPG (95.49 KiB) Viewed 5722 times
Chiadog
Post by Chiadog »
Nice simple fix. and I bet it doesn't rattle!
Chiadog wrote:Nice simple fix. and I bet it doesn't rattle!
Thanks!
You are correct. the barrier only has contact with the soft head rests and therefore it does not rattle. The first version was sitting lower and had a chance to knock against the hard seat back.
That's one pretty Golden Retriever in your avatar!
One more picture to show how I fixed the height.
petbarrier (2).JPG (93.02 KiB) Viewed 5684 times
Chiadog
Post by Chiadog »
vibrologist wrote: That's one pretty Golden Retriever in your avatar!
Thanks! she is a Sweetie, here she is saying "Throw the stick already!" :D
Rayven01
Post by Rayven01 »
Awesome! That is far nicer looking than most of the store bought ones. My dog is a small pony so I don't really need one (she's too big to fit between headrests and ceiling so she stays in the back just fine), but if I did I'd go this route.
Image  Image
There is Yogi after a swim in the pond.
Yogi after a swim (small).jpg (178.25 KiB) Viewed 5595 times
The dog barrier got 2 improvements:
1. I cut the upper corners a bit so it is possible to fold the seat backs forward without removing the barrier.
2. I used Bungey Ball loops (that's how they spell it) to tie the barrier to the head rests.
bungie loop with ball.jpg (72.92 KiB) Viewed 5348 times
bungey Ball.jpg (81.58 KiB) Viewed 5348 times
Melissa18L
Post by Melissa18L »
Awesome. Thanks for the ideas.
It's more fun to drive a slow car fast than a fast car slow!
Melissa 1.8L - 2005 Fusion Orange Metallic Moon and Tunes Gen1 AWD 1.8L "TANGERINE"
