2003 5 speed to 6 speed swap
ZERO6
Post by ZERO6 »
Has any one done this?
I have a 6 speed ready to go.
Need to know if its a direct swap???
03' Vibe GT
12' Fusion SEL/AWD
Re: 2003 5 speed to 6 speed swap
Other people have indeed done it, and as long as it is the C60 6-speed transmission (00-05 Celica GT-S, 03-06 Matrix/Corolla XRS, 03-06 Vibe GT) then it will bolt right up and work with the 5-speed parts. You'll need a new shiftknob, though (for obvious reasons).
ZERO6
Post by ZERO6 »
Have you done it?
KITT222 wrote:Other people have indeed done it, and as long as it is the C60 6-speed transmission (00-05 Celica GT-S, 03-06 Matrix/Corolla XRS, 03-06 Vibe GT) then it will bolt right up and work with the 5-speed parts. You'll need a new shiftknob, though (for obvious reasons).
03' Vibe GT
12' Fusion SEL/AWD
EricTMah
Post by EricTMah »
Only a direct bolt up if the C60 came from a Corolla XRS, Matrix XRS or Vibe GT. The celica one will work, but you'll need to modify it slightly. MWR sells the kit you'll need to make a Celica one work.
I've swapped a 5speed into my Corolla XRS as a temporary fix in the past. It literally bolts right up.
ZERO6
Post by ZERO6 »
Yes just verified it is from a GT and is the C60 tranny.
So no issues then, correct?
Just the purchase of the shifter
knob..?
03' Vibe GT
12' Fusion SEL/AWD
I have not done it myself (autotragic) but others have. In fact, someone out there swapped from automatic to the C60 6-speed. Anyway, yes, it will bolt right in, and the only thing needing changing will be the shift knob.
EricTMah
Post by EricTMah »
Are you planning on replacing anything else while it's out?
Clutch and flywheel? If yes. You're going to need to get new flywheel bolts. You shouldn't use the ones you're taking out.
Salsa Guy
Post by Salsa Guy »
Awesome....good path...but the MPGs may drop a little.
ZERO6
Post by ZERO6 »
If any knows the person that did this, please point them
in my direction..
I have a shop to do the work, but want input on "Do it Yourself".
Pretty much main reason for this thread..
Thanks Matt
03' Vibe GT
12' Fusion SEL/AWD
thebarber
Post by thebarber »
ive done it
bolts right up
mntn-biker
Post by mntn-biker »
I've done the swap also. During the swap, I replaced:
new flywheel (and ARP bolts) http://www.twosrus.com/catalog/product_ ... cts_id=304
new aftermarket clutch
new front struts (since it was apart anyway)
Here's a "How To" thread but unfortunately, the pics are no longer shown:
viewtopic.php?t=17517
2003 base model
sideshowalan
Post by sideshowalan »
Feels like i drag this link out every few months when this topic comes up.
How-to with pictures, this is a Clutch Job write-up but it shows how to remove/reinstall the trans :
http://wehavescissors.blogspot.com/2009 ... be-or.html
2008 Pontiac Vibe
2008 Toyota Sienna XLE
