While working on the Vibe last night, taking off winter tires, heard a strange noise, almost like a small drill. Traced noise to the fuel tank area. Appears the Vibe's emissions air pump turned on aprox 3 plus hours after the car last ran. I was in and out of the car, so not sure when I last had one of the doors open or key in the accessory position. Was not aware that this pump would turn on by itself. Has anyone else encountered the pump turning on hours after the car had last run? Want to see if this is a "programmed" emissions item, or if I have a wire, control, sensor etc issue. Below link to video, showing location with audio of pump running.
Vibe air pump turned on by itself:
http://youtu.be/9EREwCYvX5c" onclick="window.open(this.href);return false;
