I upgraded to LEDs also!
My inside is so bright!!
My map light has a 18led panel
After doing my inside, I wanted the outside..
So I ordered the reverse lights first.. And yeah their brighter then the stock so then I ordered the
Amber turn singls...
This is where I went to far... I ordered 4 and I don't even want them on.. Their not bright enough for daytime use.
As for fixing the hyper flash you don't need to do any wiring just replace the module under the dash.
http://www.superbrightleds.com/moreinfo ... r/786/840/" onclick="window.open(this.href);return false;
Check out this also if your interested in the LEDs
viewtopic.php?f=33&t=40564" onclick="window.open(this.href);return false;
