Stuck vent slector
kaflex
Stuck vent slector
Post by kaflex »
I went to turn the vent to defrost but it was hard, I got it to move but it went alittle too far. Now I can't move it back. Would I have to take it apart or just get a replacement?
View my garage here:
kaflex
Re: Stuck vent slector
Post by kaflex »
update:
I had time to look into it more today and think I may have found the problem. I found a cable that's not connected anywhere, I see a spot about under the pass. airbag but the cable seems to just not reach. Any ideas?
cable;
spot? the white spot;
That cable is used for disabling recirculate when you move the knob to the defrost settings.
Reconnect the cable to the bottom of the A/C and recirculate switch assembly, it will snap right in.
