I have a 2004 vibe and have had problems with the blower motor not working on any speed setting. This happens intermittently and will be fixed sometimes by hitting a bump, or closing the doors... something to shake the car. Also sometimes the passenger can wiggle the wires in the footwell and get it going. If it works when the car starts or hits a bump, it has never stopped working as long as the car was running/key turned. About 50% of the time it will not work at startup.
I had the problem and replaced the blower motor resistor, which was probably not the real problem. Anyone have any success chasing down bad connections or grounds and could suggest anything that can be done.
Thanks for the help
