I see you read my clue Dr. Watson.Salsa Guy wrote:Before changing ANYTHING post the Code from the car. Take is to a local Auto Parts store and they will do it for free. I think it's a P0171 and it that's the case it could have a bad intake manifold gasket, change the O2 sensor or MAF WILL NOT normally fix it. Which is a simple very cheap repair. The parts are less than $20 and it should be only 1 hour of labor. So less than $150 on the high end.
This guy is taking you for a ride. Head Gaskets are not normally an issue on these engines, but Intake Manifold Gaskets can be.
I just glanced over your reply and would never suggest cleaning the MAF. LOL Cleaning the MAF you can do more harm than good, it's somewhat a tender device. But the rest of your post was spot on after re-reading.Raven wrote:I see you read my clue Dr. Watson.Salsa Guy wrote:Before changing ANYTHING post the Code from the car. Take is to a local Auto Parts store and they will do it for free. I think it's a P0171 and it that's the case it could have a bad intake manifold gasket, change the O2 sensor or MAF WILL NOT normally fix it. Which is a simple very cheap repair. The parts are less than $20 and it should be only 1 hour of labor. So less than $150 on the high end.
Jeebus, how'd they come loose? Sounds like a big design flaw to happen a majority of the time.Raven wrote:I even opened them up and resoldered the contacts inside on two of the three Subaru SVX that I own.
Yes it was problem with the early SVX. My '97 has been fine. The major transmission problem sent a lot of them to an early grave.lannvouivre wrote:Jeebus, how'd they come loose? Sounds like a big design flaw to happen a majority of the time.Raven wrote:I even opened them up and resoldered the contacts inside on two of the three Subaru SVX that I own.
I have cleaned my MAF sensor a few times with the MAF sensor cleaner spray. It's very dusty down here, so it doesn't take long for it to look like I live in west TX or something. What would cause it to be damaged, if you never touch the glass temp bulb or the air flow wire (or drop it)? I realize it's comparatively delicate to most parts.
So you think the MAF sensor is ok?Raven wrote:More than likely it's just the intake manifold gasket.
