1zz/2zz spark plugs interchangeable?
Unbelievabrah
Post by Unbelievabrah »
just as the subject says, will 2zz spark plugs work in my 1zz engine?
manual says this
Base = DENSO SK16R11, NGK IFR5A11 or GM Part No. 94859448; Gap: 0.043 inch (1.1 mm)
GT = DENSO SK20R11, NGK IFR6A11 or GM Part No. 88969637; Gap: 0.043 inch (1.1 mm)
not quite all to sure what to make off it since im still learning the mechanical aspect of auto-motives except that i think heat ranges are different (off by 1 step) from econo 1zz to the more strung out 2zz engine that would appear to have to run cooler, i.e. level NGK 6/DENSO16. However, since the gaps are the same, will GT purpose spark plugs fit/operate correctly in a base car?
I live in a hot climate (los angeles) and regularly drive canyons hard so I think I would benefit from getting a colder spark plug anyways, I also would like to switch over to Copper instead of the stated iridium tip'd only plugs the manual says. I understand I will have to change these copper plugs more frequently but it should increase my overall spark yielding better performance/mileage even if they only last 15-20k tops. I will be of course check the condition of them every 2nd oil change i do every 3k miles. Will the ones i list below work in my 06 base vibe? I think they will but im just making sure by checking here. I also know that i will have to gapper to adjust the gap to the correct 1.1m distance.
http://www.ebay.com/itm/1-New-NGK-V-Pow ... c3&vxp=mtr" onclick="window.open(this.href);return false;
thanks for any input in advance for anybody replying to my topic.
Salsa Guy
Re: 1zz/2zz spark plugs interchangeable?
Post by Salsa Guy »
I'm sure it will thread right in, BUT I don't see any gains with the 2zz plug. I'd say stick with a good quality plug for your engine. Moving to a cooler plug, unless boosted will not affect the engine temp or performance one bit IMHO.
