Hi KITT,KITT222 wrote:Welcome to GenVibe! The clutch for the 03-06 may be for the Vibe GT with the 2ZZ-GE engine. Monkey Wrench Racing does nothing but the 1ZZ/2ZZ engine (mostly) and specialize in the Corolla/Matrix/MR2/Celica/Elise. Here's a link to the Exedy Stage 1 clutch they have listed for the 1ZZ engine.
http://www.monkeywrenchracing.com/produ ... ts_id=1265" onclick="window.open(this.href);return false;
I'd wait to see if your transmission is fried or if it is just a clutch at this point. The 03/04 models were the ones with the bad 5-speeds, and they fixed it in 05. Just try the clutch and if everything looks okay, give it a try.
If the splines and diameters are the same, then use the heavier clutch, it won't hurt anything and will be more stout for any upgrades. That's why MWR sells only one clutch, why sell a weaker clutch when those visiting your site are most likely upping there power levels. the stock 1zz clutch is okay for commuters, not anyone looking to actually drive the car, it's a bit flimsy.Deke wrote:KITT, I went on Monkeywrenchracing.com, and they list the same clutch for both 1ZZ and 2ZZ (ST-1 Stock replacement) - only they don't give the specs or Exedy Model number for it so I don't know which clutch it is they are recommending...
Hi Raven,Raven wrote:KTY03 for the 1ZZFE 5 speed. I'll be buying one in the spring. $110 shipped. http://www.ebay.com/itm/Exedy-KTY03-Clu ... 0a&vxp=mtr
KTY14 for the 2ZZGE 6 speed. Vibe GT
Hi Hotbug,hotbug1776 wrote:If the splines and diameters are the same, then use the heavier clutch, it won't hurt anything and will be more stout for any upgrades. That's why MWR sells only one clutch, why sell a weaker clutch when those visiting your site are most likely upping there power levels. the stock 1zz clutch is okay for commuters, not anyone looking to actually drive the car, it's a bit flimsy.Deke wrote:KITT, I went on Monkeywrenchracing.com, and they list the same clutch for both 1ZZ and 2ZZ (ST-1 Stock replacement) - only they don't give the specs or Exedy Model number for it so I don't know which clutch it is they are recommending...
Hi Raven,Raven wrote:Try calling the GM dealer parts department. Perhaps they have the specs in their data base.
Actually, now that I think about it, I believe the OEM clutch is made by Exedy.
From what I can find 8 3/8; Inner Diam : 15/16; TEETH : 21T is correct.
Yeah, I'm going to get a new flywheel, thanks.Raven wrote:I have an '06 and the part # is the same for Matrix or Vibe. KTY03 They seem to have changed in 2007.
FYI The flywheel will most likely need to be machined or replaced. If the clutch has been slipping, a lot of heat is generated.
check Amazon and Rockauto...Deke wrote:For whoever is interested:
I called Exedy yet again today and spoke with a tech rep (Steve) who admitted their website database has errors that haven't been fixed yet.
The proper Exedy OEM clutch for a Pontiac Vibe 2003-2008 with 5 speed trans and 1.8L engine is TYK1501,even though their website says it's not correct.
The KTY03 is for the 6 speed GT model, 2003-2006.
The KTY14 is probably the same clutch as the KYY03 - I don't know if there are any differences.
Don't trust me though. Call Exedy USA at 800 346-6091 and ask for tech support. And you might suggest they fix their website soon!
I've wasted a week just trying to find the right clutch for my car!
If you get different answers please post them here. I'm going to order the TYK1501 and hopefully it fits!
Best,
Deke
