Hi all
I am the new proud owner of a P.V 2006 (Base, automatic)
I need some advice on the air condition, but it was a hard one to search on, being a two word search (hence the writing it in one word for future assistance for others)
a) The air con. smelled like an old vacuum cleaner when it was on, so I changed the cabin filter wish clearly was way overdue.
It helped, but there is still a bit of that unpleasent smell/scent instead of nice crisp, clean air. Is it because I need to have the who system vacuumed professionally somehow or...? Any suggestions+
b) The air con does not blow cold air, so my guess is that it is low on freon. I have never refilled an air con myself. Is it an easy process and does it require buying several extra tools? (thinking it is something that I would have to do so rarely that its not worth spending a whole lot of extra $ on)
If I have it done by the mechanic, do any of you then have estimates on how much they will/should charge?
c) Whenever I shut off the bottom "Climate control System" button an alarming, fast-paced, knocking sounds starts. It sounds like it coming from somewhere inside the panel (on the passenger side) What could it be?
I appreciate the collective effort, time and support that has created and is sustaining this forum. I look forward to contributing in any way I can
Thank you all
P.S. Speaking on of air con. I purchased a Kenu Airframe so that I can use my iphone as a GPS, it works great - until you turn the air con on :-/
The warm or cold air will either ice or overheat your phone. A minor detail the designer did not consider (A unfortunately neither did I)
Don't make the same mistake!
