Can I dirve it wihtout the belt on?
cjb2145
Post by cjb2145 »
Recently, the bolt on the tension pulley broke on my 2003 Vibe with 315K, it's the standard 4cyl. for the motor. I need to move the vehicle forward about 15 feet to get it into my garage so I can work on it. With all of the snow and ice this time of year pushing it is a bit difficult and it's an uphill grade from where it sits to my garage. I have already removed the belt and pulley so what I'm wondering is will I do any harm to the motor by starting the vehicle and driving it forward the 15 ft to get it into my garage without the serpentine belt on?
Raven
Re: Can I dirve it wihtout the belt on?
Post by Raven »
No problem at all. It will run off the battery power for quite a while.
Chiadog
Post by Chiadog »
2X, no problem. I've driven my truck that far without any liquid in the block!
Salsa Guy
Post by Salsa Guy »
Be prepared to remove motor mounts. Replacing that tensioner can be a PITA.
cjb2145
Post by cjb2145 »
Thanks all!
Salsa Guy
Post by Salsa Guy »
Be safe and good luck!
Water boy
Post by Water boy »
Salsa Guy wrote:Be prepared to remove motor mounts. Replacing that tensioner can be a PITA.
:o
Hope the motor mounts in my 08 1zz FWD are not involved whenever I have to the tensioner.
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
cjb2145
Post by cjb2145 »
I got it in the garage and have removed the mounts. Next weekend I will attempt the bolt extraction.
thebarber
Post by thebarber »
im late, but you don't want to go far w/o the belt as the water pump won't be running to cool the engine...
Water boy
Post by Water boy »
OP stated 15 feet.
Not an issue unless the OP does a full warm up of the engine prior to the over 10 foot distance to the garage.
/sarc
2008
70,395 Battery
Salsa Guy
Post by Salsa Guy »
cjb2145 wrote:I got it in the garage and have removed the mounts. Next weekend I will attempt the bolt extraction.
Are you talking about the bolt to release the tensioner or the bolt that holds the tensioner to the block?
