got in the car and went to gas station, stopped at stop sign and the car died and will not start again. checked fuel,got fuel,checked spark has spark. ecu is not tripping any codes except for o2 censor. any help would be greatly appreciated.thanks
What code is it? Too assume it's just an O2 sensor could lead to ugly results.
it was the same code that was on there before it started doing this. the guy at autozone said its a o2 code other than that i dont know? and it is the 1ZZ-FE btw
Was the car completely out of fuel when it died at the stop sign? If so, you could have gotten air into the pump and it is having a hard time priming again.
If you don't know the code then it's really hard to say. You should know what codes it's spitting out, make a note, and not let people just clear them. I assume it will turn over. How did you check the spark and fuel?
