I have been reading posts on this site about performing connecting rod bearing replacement and am trying to undertake this work for my Vibe. As background, I am getting a metallic knocking sound on acceleration. It started out only when the engine/transmission were cold but can now be heard almost all of the time. I took it to a mechanic and they diagnosed it as either lower-end engine noise or the timing chain (and possibly timing chain tensioner). From reading on this site it appears that the connecting rod bearings are the most likely culprits and the symptoms do seem to match mine. viewtopic.php?f=20&t=30525&p=472276&hil ... gs#p472276" onclick="window.open(this.href);return false; by silverbullet. I will probably replace the timing chain tensioner too.
Now to the question. When I called the Toyota dealer about ordering connecting rod bearings they said they need a "mark number" which can only be found on the existing bearings. This would involve opening up the engine, finding the number, ordering the part, waiting several days for it to arrive and then closing the engine back up. I unfortunately don't have the luxury of letting my Vibe sit partially torn down for that long. It would seem to me that the VIN # would uniquely identify everything in the engine (although it is a Pontiac/GM VIN so that may have been the problem) but the Toyota parts guy didn't seem to think so. I would have guessed that all 1ZZ-FE engines of the same model year (i.e. 2003 Vibe/Matrix) would use the same rod bearings. Does anyone have experience with this kind of thing?
