I am getting a tire / grinding noise from the right rear of my 05 AWD Vibe. After reading multiple posts and following
http://forums.genvibe.com/files/importe ... 040001.pdf" onclick="window.open(this.href);return false;
I realized there had to be an easier way. The trick to removing the hub is to have a 12mm 1/4" ratchet and socket with extensions and a 3/8" drive and 3/8 to 1/4" adaptor.
First I fought to get the right rear axle nut off (it is a RH thread on the right side). Use the parking brake to hold the drum, soak the nut with PB Blaster and let it sit. A breaker bar and a 30 MM socket will get it off.
Now for the 4 fun bolts. Get under the car and use the small socket, it goes straight on the nut with the small socket, use the 3/8 to 1/4 adapter and give leverage. The top left bolt can be easily accessed from top. The nuts do not have to be taken completely out once off the hub. The hub will come free. Took me about 15 minutes to get the bolts out. I have ordered the hub from Rock Auto and will reassemble later this week.
