No. I'd either make an insurance claim or replace the fuse box myself.vibebox wrote:So your saying im probably better of getting a after market kit and wiring it up
Have you check if the side power mirror still works as well as the Windows and the door locks....vibebox wrote:I have a 2010 Vibe. Earlier this year it was struck by lighting along with the LP tank it was parked next to (LP tank fire was put out with no major damage). The lighting strike scorched the drivers side mirror and caused the horn to be stock on so i removed the fuse.
I am trying to fix it with out taking it to the shop. I can still hear the switch in the steering wheel activate, so i am assuming it is the horn relay which i am having a hard time locating on the vehicle.
Where is the horn relay located and does any one have a picture of it?
Also is there anything else that may cause the horn to stay on?
ParknVibe wrote:Have you check if the side power mirror still works as well as the Windows and the door locks....vibebox wrote:I have a 2010 Vibe. Earlier this year it was struck by lighting along with the LP tank it was parked next to (LP tank fire was put out with no major damage). The lighting strike scorched the drivers side mirror and caused the horn to be stock on so i removed the fuse.
If the fire was at the mirror I would check to see if the wires are okay and there is no electrical shorts within the door.
When they say that there is no servivable parts in the relay... means that you must replace it (unplug it from a socket. ...It says in my BIG service manual of the 2009 Vibe.....Horn always on....Remove the horn relay.
IF you have the manual....Pages 4-46....is the diagnostic for the horn.
I haven't really looked at the fuse box so I don't really know which one it is....Horn relay PCB.
I have AllData, which is basically an electronic copy of the GM manual. Hm.ParknVibe wrote: It is the GM Service Manual for the 2009 Vibe. It is a three book (three NYC phonebook) size set. About $150.00 from Helm, Inc.... who makes them for GM. I purchased it at the time I got the Car.
http://www.helminc.com" onclick="window.open(this.href);return false;
I see it is still available for $200.00 now
kumquat wrote:For the 2.4L, AllData says "If the horn is always ON... replace the BCM."
I think I'd go and remove the current BCM and look up its part # on eBay.
BTW: If you want to view the pictures and enlarge or zoom in to read it....Just place the mouse pointer over the each photo and right click the mouse and use "Save picture as.."...These jpg photos.vibebox wrote:With the horn fuse removed everything thing else works as normal
