Hey guys...
It's been a looooong time since I have been here and posted but I am in need of some help/information. My 03 GT won't start and I am trying to diagnose the cause. The other day it started fine so I could pull my car off the street and into the driveway. After backing it in and loading it up it wouldn't start. My first thought is the battery but I am pretty sure it checks out fine. I put my meter on it and it seems to have enough voltage. All the lights (including headlights) come on fine, stereo comes on, I even hear what sounds like the fuel pump in the back running when I turn the key but the engine won't turn over. Nothing. no sounds of turning over or trying to start. I am going to try and jump it but for the sake of assuming the battery isn't the problem....my question is this: Are there any known issues with the starter switch konking out and allowing the power to the vehicle but just not making a connection to the starter. Also....is it possible the switch that the clutch connects to when depressing it to allow the engine to start has died? It may be my imagination but it seems recently before this happened that I had a few instances of when starting the engine it would suddenly stop turning over and I would have to turn the key off and and then back on to start it. It may have been me not putting enough pressure on the clutch at the time. Anyhow....thanks in advance for any information or insight anyone may have.
Thanks, Jim
 so I think I'll go out any buy a pair so I can attempt to jump it from my Jeep just to be 100% certain on the battery. If the battery is indeed not the culprit am I correct in saying my next move is to pull the starter and have it tested?
