I can say call ahead. I called my local Toyota dealer and when asked about my car, he responded, "I don't work on no Pontiac's".gjswaff wrote:XRVibe10,
And one more thing, if I take this in to get checked out, would I be better off taking it to a Toyota dealer or a (Former Pontiac) GMC/Buick dealer. I've had this '09 GT with only 42,000 miles since late June and up till now haven't had any problems. I'd like to take it in just once for this problem and be done with it. I ask because you seem quite knowledgeable about the Vibes.
Nasmfell wrote:gjswaff wrote:XRVibe10,
XRVibe10 wrote:The rattle in the steering column is just coincidence - I've mentioned in a few posts about noise from the steering column (same noise issue that the cobalts & pursuits/G5 suffered from) - I put 4 columns in my car for noise issues but to just have them return - the rough roads with the lower profile tires make things worse & with winter approaching & temps getting cooler the noise gets worse - the noise I wouldn't worry about (Toyota has a bulletin about I-Shaft concerns, I may give this a try when I have some free $$$) - Like 09vGT said, ruts are not your friend - as for taking it to a dealer, if you have one you prefer to deal with take it there - I was @ a Pontiac Buick GMC dealer when Pontiac was cut from the lineup & now I'm @ a Chevrolet Cadillac dealer - depends on where you are you may have to go to a former Pontiac dealer (for warranty that is) as some Chevrolet dealers are blocked by GM for performing work on certain Pontiacs (we are able to work on all Pontiacs @ my work except the G8 for some weird reason) - if your out of warranty any dealer can look @ your vehicle and advise you from there - some Toyota dealers are funny about working on Vibes for some reason (even though it is there vehicle) so you may have to call around to see if any are willing to help you out if you choose to go that route - Hope this helps out some more - let us know if they find anything
That just isn't quite so. Pretty much the entire interior other than the button in the center of the steering wheel is toyota.Nasmfell wrote:XRVibe10 wrote:
Vibe really is a GM product. Only Toyota parts are the drivetrain, the rest is all GM.
leemur wrote:That just isn't quite so. Pretty much the entire interior other than the button in the center of the steering wheel is toyota.Nasmfell wrote:XRVibe10 wrote:
I got a grin a couple months ago when I looked into an 01' toyota Celica and found the 03-08 steering wheel in it. OEM.
Nasmfell wrote:Vibe really is a GM product. Only Toyota parts are the drivetrain, the rest is all GM.
