Set of 4 TPMS sensors
BaseWhiteVibe
Post by BaseWhiteVibe »
I have 4 TPMS sensors off my old wheels, 2 are perfect, 1 is cracked where the stem bottom mates to it but it still works, 1 has a really weak battery would be thrown in the deal. Make me an offer, I can take care of shipping as well
Re: Set of 4 TPMS sensors
I may be interested. Will check with my son as he has at least ONE bad in his 2009 Vibe GT and I'd like to get it fixed. Will get back with you soon............... Tim
BaseWhiteVibe
Ok let me know! 2 are perfect and 100 good to go! The one has a crack at the base (so on the inside of the wheel) but still works 100%. The last one has a weak battery and won't be long for this world... Rebuild or Crazy Science experiment!
You are relatively close but I would probably just ship to you
I just checked with my son and he said ALL his sensors are good, but nobody we know knows how to program them. He had all tires replaced and one TPM sensor at the same time (he found one on-line at the time) but the shop that installed them primarily works on large semi's & tractor trailers NOT passenger cars. It was a friend of ours who owns the shop and owed my son a favor so we got a good deal. Anyways if what he tells me is true then I won't be needing them. I'll try to find out fact/fiction and get back with you soon :)
BaseWhiteVibe
OK just let me know
BaseWhiteVibe
Still got them, asking for $35 for all four
1. 2 of the sensors have no issues and work fine, the mount nuts and washers have paint on them from when the previous owner painted the wheels. I was able to clean one off somewhat easily with steel wool
2. 1 of the sensors works BUT has a crack at the plastic part that goes into the wheel. IT STILL WORKS AND DOES NOT LEAK AIR! Also has some paint spray on the mount nut and washer
3. 1 sensor is intermittent AND I AM SELLING IT ONLY AS PARTS/NON WORKING! It comes with the mount nut and washer which has the paint over spray on it. The part will be CLEARLY marked that it is to be used as parts!
Email me for pictures
