I have a 2007 Vibe & finally decided to do something about the abusively harsh ride.
The car is all stock with 35K & a couple months ago I decided to have new struts installed.
I chose the Monroe OE Spectrum units & had them installed at the local Sears here in Bend.
The ride is only slightly smoother, im guessing compression damping is about 85% as stiff as the original struts.
You still feel every little crack in the pavement & get your teeth rattled driving over any little
imperfection or at every painted crosswalk.
The rebound damping is very much improved & the incredible wobble you get while making a
turn in an intersection (over uneven pavement) is reduced.
Unfortunately, I wanted a shock with a nice ride & the OE Spectrum's are NOT the ones to get.
What a waste of $700 dollars (installed). I really feel Monroe has put out a "totally improper offering"
for the Vibe & would not recommend it at all. It's a little better than stock, but you all know what that is.
