Because maybe the OP suspects it's the transmission, but doesn't know if maybe it could be something else. Or maybe the OP is not as knowledgeable about cars. Not everyone is. I know I'm certainly not. Just because you know a lot about something doesn't mean everyone else does.thebarber wrote:Snarky or not, he's right....how could you not think the tranny is cooked?
If you read your comment as if you were a stranger, I'm sure you'll agree that there's no way someone would take what you said as "kidding". And that's at least the second time (that I've seen, let alone anyone else) that you've posted something that was supposedly "kidding" that would never in a million years be construed as kidding by anyone.creekhed1 wrote:It wasnt a joke>?
I seriously did not think OP was serious!
I didnt mean to be "snarky"... but when a tranny grinds to a halt and wont go on either direction that means only one thing ...
And....its YOUR post that is venomous,....not mine! I was kidding!
In front wheel drive cars the word transaxle and transmission mean the same thing.ed357 wrote:Creekhed1, Yes, I was serious. Not everyone has knowledge regarding cars. I thought it was the tranny, but I wanted to confirm and also get more opinions. I also was told that it can be that the transaxle broke. Anyway, thanks everyone for the help and replies.
ed357 wrote:Yes, there was no fluid leaking and the axles are intact.
I'm sorry to revive this thread, but I'm experiencing exactly the same symptoms as ed357 and I wonder if he figured out what was wrong with his transmission.ed357 wrote:I was driving my car and when I turned left my car made a loud grinding sound and eventually came to a stop. Now, when I put it in drive or reverse its making the same noise and I'm unable to drive or reverse. Also, while in park when I push the car
it moves.
blacksaabath wrote:I'm sorry to revive this thread, but I'm experiencing exactly the same symptoms as ed357 and I wonder if he figured out what was wrong with his transmission.ed357 wrote:I was driving my car and when I turned left my car made a loud grinding sound and eventually came to a stop. Now, when I put it in drive or reverse its making the same noise and I'm unable to drive or reverse. Also, while in park when I push the car
it moves.
I recently purchased an 03 Vibe base model with the Automatic tranny FWD, with what I though was a bad transmission. The previous owner claimed that he was driving normally, when it came to a red light and then tried to go, the car wouldn't go. The I put the transmission in D or R or L or 2, the transmission just growls but the car doesnt' move. We though the transmission was toast, so I found a used transmission from a Matrix with a torque converter and swapped it into the Vibe. I also replaced one of the CV axles, used new filter and fluid and double checked everything to make sure the installation was perfect. But when the moment of truth arrived, the transmission did exactly the same, it growls when you put t in D or R, doesn't move, and if you put the car in Park, it will still move if you push it. The car has 140K miles, and the transmission supposedely had around 70K when the donor car was involved in an accident.
It would be very unlucky if the donor transmission had exactly the same issues as the one I replaced. Does anyone have any idea where I should look at? Thank y'all
I think what he said was that in "P" the car can be pushed. That means the parking pawl does not engage.The fact that it moves in PARK eliminates the torque converter/flywheel and leaves only a failure AFTER the transmission.
You should be able to rule out the torque converter/flywheel. You can remove an engine and PARK will still work! So for my 2 cents, its the transmission or driveline down stream.blacksaabath wrote:Thank you for your input guys.
....I will focus on the mechanics again, I used the torque converter that came with the donor transmission, it look cleaned, no debris and no dirty fluid inside, but neither the old torque converter seemed dirty.....
Thank you again, I'm not giving up on this Vibe yet.
The cv joint can still be broken inside the boot. You said it happened during a turn so a bad cv joint is a very likely possibility.ed357 wrote:Yes, there was no fluid leaking and the axles are intact.
