I like the washer idea. But epoxy will not hold up. I would drill two small holes into the washer and matching holes on the remaining flange on the fender. Then I would connect the washer with solid copper wire. Try to get a stainless steel washer. Perhaps a fender washer...if you know what that is.. but just get the correct size that is required.Chiadog wrote:Oopsie, While backing off my ramps after an oil change I heard a bad noise. It was my 05 Vibe's nose being broken! Has anyone crossed this bridge? I'm not seeing a simple and cheap fix, but I did learn a lesson! Never change your oil!
Well what you did won't make it worst. The holes I speak of don't need to be more then 1/8 inch in diameter.Chiadog wrote:Thanks ParknVibe!
I've already epoxied the flange to the washer and I'll be supporting the front of the snout, with straps or coated solid copper wire, to the hidden front bumper behind the fascia for extra support.
I'm afraid to drill into the remaining tab because it is very flimsy and I don't want to chance weakening it further, but as a last resort????
If anyone has successfully fixed this problem, I'm all ears!
Thanks Guys!
Being that the location is at the wheel opening, Water, snow, ice, road debris, stones. and wind will still knock it apart in few minutes of driving. You must have a mechanical fastener and not glue. Another possibility would be to weld or melt a PVC plastic to the spot. Plumbing solvient that welds or fuses the plastic to plastic.
Yes, the washer is epoxyied at the torn-out mount hole shown in the initial picture in this thread!ParknVibe wrote:So is the washer is attached with epoxy at the wheel well?
Your pictures are showing another fender attachment problem.
I lost the code book in my last garage fire.BTW: You need firecode sheetrock and prehap insulation on your garage ceiling.
If this is an attached garage to your home, you have a building code violation.
