I've had an 03 GT for three days and have a gripe which a google search can't match. That is the throttle tip in is too quick. What throttle tip in is the rate the throttle opens vs the amount of pedal movement, off idle. This makes launch far too tricky and probably has contributed to many premature clutch failures.
It used to be a notorious Big Three trick to have the throttle open quickly so that people thought the car was powerful and fast. A design was used to make the throttle open fastest off idle and then progressively slower the more the pedal is pushed. I am almost positive this is the case with the GT. After all you probably notice that you can cruise at 80 at about 1/10th throttle, or is it 1/20th. Whatever it's stupid. Even my 140HP Kawasaki needs at least a bit more percent of throttle to cruise 80, Any push of the pedal when not in gear brings the RPMs to 2500. Just try to hold it a 2K.
Am I the first one to notice this. A slower tip in would improve driveablility a lot. Maybe later years changed this by changing the design of the arm on the throttle. I hope so, Trying to design and fab one would be hard but I absolutely hate the driveability now and too boot a more accurate throttle would surely lead to better MPG
