Changing oil with suspension drop
dmitri
Post by dmitri »
im gonna do it today but is there any place in front to jack it up? like under the engine somewhere? (i know its a sub frame and i dont want the engine to pop out lol)My jack doesnt fit under the frame with the drop, so what i do is take the factory jack and lift it up enough to get one in then i go to the other side and do the same thing just with my other jack, and have my dad jack it up at the same time as me. gotta be an easier way lolshould have thought about oil changes when i had my car up on jack stands takign the resonator off
Triton
Re: Changing oil with suspension drop (dmitri)
Post by Triton »
How much of a drop do you have? Or what kind of jack are you using? I have used a floor jack under mine with no problem and I have a 2" drop on mine.
***SOLD***2003 Vibe GT Monotone Neptune - Inaugural October 2004 Vibe of the Month***SOLD***
Now the proud owner of Titanium Silver 2012 Kia Optima SX
ragingfish
Post by ragingfish »
According to the matrix owner manual, and backed up by Geo's testimony, there is a center jack point under the engine block you can use to lift the car off the ground and get it on stands, should you choose to do that:(Click the image to see a full size version of the picture.)
2009 PONTIAC G8
MadBill
Re: Changing oil with suspension drop (ragingfish)
Post by MadBill »
You could also just drive the front wheels onto a couple of lengths of 2 x 6.
dmitri
Re: Changing oil with suspension drop (MadBill)
Post by dmitri »
nah i have ramps and i cant get up them in the front cause its too low lol.i have the progress springs.
You could cut a couple pieces of a board to make two small steps, creating a very token platform about the same height as what you lost when you did the drop, then all the jacking points would be back at the stock height and you should be able to use jacks the way you did before your dropped it.
MadBill
Re: Changing oil with suspension drop (joatmon)
Post by MadBill »
That's what I meant with the 2 x 6s: lay them flat, drive up on the resulting 2" high "ramps", regain the pre-drop ground clearance, use the jack as before...
That's what I thought you meant, but seemed like he took it as a suggestion to make ramps out of 2x6's, which is still an option, just need to make them gentle enough to be able to drive up.One place i lived there was drainage ditch on the side of the road, and I could straddle it with the car, sort of a natural mechanics pit.
rainvibe
Post by rainvibe »
Hope the neighbors didn't see you chaging the oil into the drainage ditch! You did have a catch pan didn't you?
03 Frosty GT MonoMoons and TunesPower GroupModsSilverstars OUT GE Nighthawks INMud FlapsRear Bumper ProtectorCustom "Lowes" rear mat
Re: Changing oil with suspension drop (rainvibe)
duh what's a catch pan?yes, of course
rainvibe
Post by rainvibe »
I knew, no Vibe person would consider doing that. Handy where I live, they take the oil away with the trash pick up, along with all our other recycle materials!
