XRVibe10 wrote:Your Vibe is looking really nice! Great Job - your info on the TRD lowering springs is what I've been looking for - I have a base 2.4 as well with the front TRD brace & rear sway bar & have been toying with the idea of those springs - I'm looking for better handling without much sacrifice on ride quality or being too low (thats what my other car is for) - how is the overall ride quality for daily driving with the springs? Also, are those yellow fog lamp assemblies a direct fit for mounting or did you have to mod them? I have 3000K yellow HID's but I'm liking that look - Thanx & Keep up the good work!
Thanks! I was wary about dropping too low because of the terrible roads around my city
Plus having a smooth ride was ideal because of the baby in the back. The TRD lowering springs WILL drop your Vibe ≥1", so ride quality won't be sacrificed PLUS they aren't enough of a drop to destroy the stock shocks. The springs are built differently than stock, so maneuvering feels a bit more nimble and daily driving is always excellent. I figure since it's made to enhance (and not destroy) a 2010 Matrix, it will do the same with it's sibling
Because I didn't have fog lights installed before installing my fogs, I just had to drill out holes to mount the lamp. The fogs I ordered lined up perfectly, so if you have fog lights already installed, I believe they would be a direct bolt-on. I just did a search for "yellow 2008 camry fog lights" and went for the less-pricey set. It comes with the Camry fascia, but you can toss or recycle them. If I remember correctly, I got them from here:
http://www.racinglab.com/oem-fl-kit-070 ... ellow.html" onclick="window.open(this.href);return false;
Infinity-x wrote:Looks good! Do you have a direct link to the spoiler that is already painted? I have the same color as you and would like to look into doing this modification as well. Thanks in advance!
Thanks man. For a reference, I bookmarked this page:
http://www.gmpartsgiant.com/oem/2009-po ... 10058.html" onclick="window.open(this.href);return false;
Since you have the same color as my Vibe, the part number is: 19171939. Really, all I did was google search the part number, but gmpartsdirect.com will probably net you the best price under $200. Good luck!
