I have had my current lighting setup (Nokya hyper yellow Stage 1 bulbs in the fog lights and Sylvania SilverStar zXe bulbs in the low and high beam headlights) for a little over a year now, so I am expecting at least one of the bulbs to be burning out soon, so I have been considering getting some HID bulbs from DDM Tuning (35w - 3000k for fog lights and 5000k for low beams). I have a question for you though: 1.) How much did you aim your headlights down i.e. one full turn of the adjustment knob, etc.? I would really like to give HIDs a try to see if all the hype is true, but I don't want to be one of those idiots driving around blinding everyone else on the road. Thanks in advance!XRVibe10 wrote:I have HID's in my Low Beams (6000K) & Fog Lamps (3000K) - Install is simple plug & play - You won't need to get the relay harness for the Low Beams as the DRL's run on the high circuit (if you get a really cheap kit, you may need to get the relasy harness to bump up the voltage) - I have the Litech Brand - Very simple & haven't had any issues - make sure where you mount /hide the ballasts it is away from where water can get on them (I hid mine behind the black splash shields on the upper part of the front fenders near the strut towers - There are mixed feelings on the use of HID's in open headlamp housings - Vibenvy made a good point that ideally, HID's should be used with projectors (no aftermarket sets i've seen yet for our Vibes, but retrofit can/has been done) - Check my signature for the Auto Disable, there are pictures of the HID's - just make sure you check your aim, a common mistake many people forget when you install new lights, espically aftermarket lighting - the 09/10 Vibe headlamps have a unique design which kinda gives a somewhat flat cut off line which helps with the glare/scatter issue - Good Luck
Thanks for the tips! No crazy colored HIDs for methebarber wrote:the best thing to do for aiming is to mark where your beam is concentrated on a wall (or garage door) with your current bulbs. don't move the car and install the HID's. youll see the new pattern on the wall once you install the HID's, id aim the main focus of teh beam pattern to about the same level as the old ones, or a bit lower.
its not an exact science.
and yes, you'll notice a difference between your halogens...just don't get a stupid blue colour.
i have customers asking me all the time if the higher the colour temp the brighter they are. all 35w hid's are the same brightness. its the colour that makes the difference in visibilty at night. imagine looking around your house at night with a flashlight with a white bulb....now imagine looking around the house with a blue or purple filter on it.....the white will be superior.
personally i ONLY run 4300k or 5000k in the headlights and my preference is 3000k in the fogs.
but to each their own...i sell a lot of 8000k, 10000k, 12000k HID's
You finally gave in! I've yet to install mine. I need to get on that.vibenvy wrote:Just placed my order with DDM Tuning.... 35w 3000k H10/9145 HIDs for the fog lights and 35w 5000k 9006 HIDs for the low beam headlights ($81.86 shipped). Once I receive the HIDs and get them installed, I am thinking I am going to order a pair of these to replace the high beam bulbs (even though my DRLs are disabled).
I don't think LED's are that bright for headlights. I was in my friend's 2014 lexus IS350 f package that has the LED headlights and it's pretty dim compared to my HID set up. He too was a bit disappointed since his old TL's reflector HID was brighter. Would be interesting to retrofit one of those LED headlights into the vibethebarber wrote:I have yet to find an led worth putting in a headlight...they're never even as bright as halogens...
Yes, I finally gave in09vGT wrote:You finally gave in! I've yet to install mine. I need to get on that.
I got the 6000K. I got one installed and it seemed a little loose in the housing. I took them out. Accessing the bulbs is a huge pain (for me). I'm waiting for a friend to put them in since he works on cars a lot.vibenvy wrote: Yes, I finally gave in! Worst case scenario, if I'm not happy with them, I will just sell them. What color did you get and did you get them for just the low beams or the fog lights too? You need to get them installed! From everything I've seen, they're super easy to install. I'm already planning on putting the ballasts for the low beams behind the little black plastic pieces along the fenders in the engine bay and the ballasts for the fog lights will go somewhere behind the bumper cover where they will be protected from water, etc. I'll be sure to post pictures and perhaps a how-to once I get them installed.
As far as the LED bulbs for the high beams, they will be mostly for looks and basically just to fill the need for a bulb in the high beam harnesses. According to everything I've ever seen online, I shouldn't really need to use high beams if I have HIDs in the low beams and fogs.
Sorry for the late reply - my adjustment wasn't so much of how many turns as that may vary on how the headlamps were aimed originally - I parked about 25 ft or so away from a wall (nice flat floors in the shop!) & did my adjustment that way. I made sure both sides were level & not up too high or straight forward - there is a proper procedure if you really want to aim your headlamps, but I don't think they apply to HID's, only Halogen - Hope you HID's worked out for you!vibenvy wrote: I have had my current lighting setup (Nokya hyper yellow Stage 1 bulbs in the fog lights and Sylvania SilverStar zXe bulbs in the low and high beam headlights) for a little over a year now, so I am expecting at least one of the bulbs to be burning out soon, so I have been considering getting some HID bulbs from DDM Tuning (35w - 3000k for fog lights and 5000k for low beams). I have a question for you though: 1.) How much did you aim your headlights down i.e. one full turn of the adjustment knob, etc.? I would really like to give HIDs a try to see if all the hype is true, but I don't want to be one of those idiots driving around blinding everyone else on the road. Thanks in advance!
The Litech brand I have comes with the required ballasts & harnesses to plug & play into your factory connectors - depending on the brand (or if you have DRL's on that circuit), you may also have to purchase a relay kit that supplies 12V directly to the system, using the factory connectors as a trigger signal only (I didn't have to use it with my kit, but I have seen cheap kits that needed the harness as the lights would not ignite (HID's like 12V supply) - My 6000K have a white/slight blue tint & my 3000K are yellow, the yellow in the fogs are bright as daylight - the 3000-6000K range is the best for light (8000-10000 are very blue & 12000+ starts getting purple, looks cool, but absolutly no visible light out put) - Hope this helpscanadave wrote:So, for us people clueless about HID's....a lower temperature bulb (3500-5000) will always be whiter than a higher temperature bulb?
Also, just to confirm...you're saying there are HID's, such as the other person's LiTech HID's, that install just like regular bulbs? no special harness/wiring needed?
Yep - I've had DDM HIDs in my lows and fogs for 3+ years now with no flickering or any other issues...thebarber wrote:Anyone else run hid fogs in an 09gt?
thats themvibenvy wrote:these be the same as the capacitors/anti-flicker devices you mentioned?
Well, we are once again back to using the Nokyas in the fog lights of both Vibes. A couple weeks ago, my mom was driving behind me in her Vibe and I noticed her fog lights were a very odd orangeish color instead of the yellow they're supposed to be. It looked horrible, so I decided to remove the HIDs from the fog lights of both Vibes and switch back to the Nokyas for the time being. I am going to try some Morimoto Elite 3Five 3000k HID bulbs and see if they make a difference. They go for $30.00-$40.00 a pair on eBay, so I am hoping paying a little more for a great brand like Morimoto will make a difference. If for whatever reason, I'm not happy with the color of the 3000k bulbs from Morimoto, I am just going to stick some 5000k bulbs in the fog lights and be done with it.vibenvy wrote:An update on my fog light HID saga...
I ended up not submitting a warranty claim with DDM. I just switched back to the Nokya bulbs for a while. A few weeks ago I decided to order a wiring harness from eBay as a last resort. It arrived and I installed it. Got everything all hidden nicely and all, turned the fog lights on and the bulbs still flickered! After PMing back and forth with XRVibe10 a couple times, I decided that the DDM #9145 / H10 bulbs must just be cr@p, so I ordered a pair from hid-led-outlet-store on eBay (same place I ordered the wiring harness from - $12.95 a pair with free shipping). The bulbs arrived within a couple days (instead of a couple weeks like DDM) and came from California (not China like DDM). There was an immediate visual difference between the two brands of bulbs, the ones from eBay are significantly shorter then the DDM ones (the bulb itself). This gave me hope that they would work, so I got to work installing them. I got everything all connected, turned the fog lights on and... THEY DON'T FLICKER! I was able to hook them up just like the HIDs in the low beams are hooked up (factory plugs connected to ballasts and amp connectors on bulbs connected to igniters). I was also able to remove the wiring harness which was nice (no more extra wiring all over the place behind the bumper cover). I am so happy that all my lighting is finally working properly! I'm taking the Vibe out for a cruise in a bit to see how they are at night while driving
