light in master window switch panel
07cdnvibe
Post by 07cdnvibe »
I have installed lights into the master window switch on the drivers door, the lights also allow light to shine around the other switches in this panel, I only have the one pic but will post some when it gets darker and the lighted effect is easier seen.Image
here is a pic of the panel lit up
Doug14
Re: light in master window switch panel
Post by Doug14 »
nice! sweet mod!
07cdnvibe
Post by 07cdnvibe »
thanks,
Derf
Post by Derf »
Did you source the power from within the door, or run a wire into the dash for power?
2005 #10,524 Neptune Vibe "Bandit" Auto, Moon & Tunes 238k :D
1991 Pontiac Bonneville 3.8L "Granny's Whip" 142k (33nd Anniversary :o )
07cdnvibe
Post by 07cdnvibe »
Right now I am using an ignition wire to the power windows but it is on all the time I will be running a wire from the headlight circuit for power very soon then it will only be on at night as I run my park lights all the time so that would be no different than using the wire I am now
