2003 Vibe AWD With a similar problem as viewtopic.php?t=30913" onclick="window.open(this.href);return false;
BACKGROUND:  My son wanted a bright LED version of the 2005.  He bought a used 2005 cluster to later find out it would not interface as the 2003 because of the addition of a separate plug.  Fair enough. So, he connected the 2005 plug that fit to the 2003 "to make sure it worked" before returning/reselling.
THE PROBLEM:  After reconnecting the original, PROBLEM FREE, 2003 cluster, the gas gauge is--I'm assuming--not working properly.  The car had nearly a full tank of gas before the ingenious cluster swap attempt.  Now after a handful of miles, the fuel gauge is displaying almost a quarter tank left.  The car is running great.
Would unplugging the battery for a while reset anything?
Some help would be appreciated.  Thanks.
Once the gauge shows near empty, I will fill up to see how many gallons it takes.)
