Looking for supercharger kit complete
millsracing
Post by millsracing »
I'm interested in buying a complete supercharger kit for 08 Vibe with Auto. I know these come up from time to time. Located in SE USA, regards Eric
SeattleJeremy
Re: Looking for supercharger kit complete
Post by SeattleJeremy »
I'm going to quote Salsa Guy from this thread, because it seems relevant.
viewtopic.php?f=46&t=41440" onclick="window.open(this.href);return false;
Salsa Guy wrote:If you have an FWD 05+ Vibe/Matrix/Corolla you'll need the throttle body adapter. Also The TRD ECU will NOT work on your car.
If you have an AWD/4WD 03-06 Vibe/Matrix you won't need the TB adapter and can use the TRD ECU.
For a used complete kit in good shape will run about $1.5K. An AEM FIC 6 (Piggyback) will run about $300 then Tuning will run about $200 to $300. This isn't including an adapter wiring harness for the AEM FIC 6 which is $200 but it can be hard wired if you can solder and read wiring diagrams. These things can be purchased used about 50% or less than new.
millsracing
Hunt for Supercharger complete, thanks for help
Eric
Salsa Guy
Post by Salsa Guy »
SO you found one? Awesome! That's the easy part. The install isn't that bad. The Tuning will be a pain with the O2 spoof.
millsracing
I used to do tuning on Audi and VW 1.8 turbos at APR years ago, so if there is any tricks or minor things I should be aware of for tuning, that would be extremely helpful. I plan on getting the AEM box and I know I can handle tuning once I have all stuff installed.
Eric
