So this is my second Vibe...and BOTH have had problems with the Temp control cable breaking loose from its "Clip" that holds it snug behind the dash causing it to .... be non operational!
What up with THAT!
Try as I might, I cannot locate the clip that this cable goes into that holds it in place. Because of this, it will not open/close the vent door as it is just flopping around back there when I turn the dial. It IS connected to the dial itself...but there is also a clip that this cable is supposed to be attached to that holds it snugly in place.
Anyone have a pic of the cable routing? I looked for hrs on the net to no avail.
HELP!
thnx!!!
