Hi, I am new to forum, had my 06 vibe GT with 6 speed for 4 years, 180k miles. I thought I had it sold, and gal took it for a test drive, 3 weeks later, she called me to tell me to pick it up, said it needed a new travertine belt. I went to get it, and the belt was GONE. I towed it back 4 blocks to my house, replaced the belt, and tried to drive it out of the garage. Engine starts, I can put it in any gear, but it absolutely does NOT move. I can put it into any gear.... and it doesn't matter if I have the clutch in or out. NOTHING happens. (yes the engine is running while this happens) I can put it in gear, and it will roll around as though it is not in gear, when engine is off.
What am I to think? It is like the clutch is stuck open, without the throwout bearing being engaged. Is there a cable or something on the outside of the case that I can check? Can the throwout bearing "over center" and be stuck open? thanks for any insight.
